Asus X200MA Speaker Replacement
  1. Asus X200MA Speaker Replacement, Back Panel: step 1, image 1 of 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Speaker Replacement: step 2, image 1 of 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Speaker Replacement: step 3, image 1 of 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Speaker Replacement, Speaker: step 4, image 1 of 1
    • Disconnect the gold cap that connects to a black wire using the metal spudger.
  5. Asus X200MA Speaker Replacement: step 5, image 1 of 1
    • Remove the plastic component from the clip by gently pulling it back.
  6. Asus X200MA Speaker Replacement: step 6, image 1 of 2 Asus X200MA Speaker Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to free the speaker from the plastic clips.
    • Use a finger to lift the speaker and break the bond between the adhesive on the base plate and the speaker.
  7. Asus X200MA Speaker Replacement: step 7, image 1 of 3 Asus X200MA Speaker Replacement: step 7, image 2 of 3 Asus X200MA Speaker Replacement: step 7, image 3 of 3
    • Use the tweezers to carefully lift the wires from the plastic clips.
  8. Asus X200MA Speaker Replacement: step 8, image 1 of 2 Asus X200MA Speaker Replacement: step 8, image 2 of 2
    • Use the metal tweezers to free the speaker from the plastic clips.
    • Use the metal spudger to break the bond between the base plate adhesive and the speaker.
    • Lift the speakers and remove them from the base plate.
To reassemble your device, follow these instructions in reverse [#|order].
Alli Krininger
391 Reputation
3 Guides authored
IUPUI, Team S2-G4, Stella Fall 2019 Member of IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 533
