Asus X200MA Wireless Card Replacement
Vanessa Garcia
Vanessa Garcia and 2 other contributors
Last updated on June 9, 2015
No estimate
Moderate
Better Introduction
Tools
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Asus X200MA Wireless Card Replacement, Back Panel: step 1, image 1 of 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
    There are also two other screws under the rubber feet above the battery.
    digg1024 - Reply
    I agree. Two another 14 mm screws under the rubber feet.
    shao.onii - Reply
  2. Asus X200MA Wireless Card Replacement: step 2, image 1 of 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Wireless Card Replacement: step 3, image 1 of 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
    How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
    Clément Marshall - Reply
    Look at comments in the previous step. There are 2 more screws.
    Károly Varga - Reply
  4. Asus X200MA Wireless Card Replacement, Wireless Card: step 4, image 1 of 1
    • Take gold cap that connects to a black wire off using the metal spudger.
  5. Asus X200MA Wireless Card Replacement: step 5, image 1 of 1
    • Remove the following two screws:
    • Two 4 mm screws using Phillips #0 screwdriver.
  6. Asus X200MA Wireless Card Replacement: step 6, image 1 of 1
    • Slide the component up and out.
    Hi, i want to add bluetooth modul on my x200ma, but bluetooth dongle doesn look prety good and not portable enough if we always plug it into usb port, so can we change wifi modul on this model with another modul that say 2in1 wifi+bluetooth?
    If it work, which type modul i can use?
    Thank you. Sorry my bad english.
    Yudha Mobile - Reply
2 other people completed this guide.
Vanessa Garcia
1,796 Reputation
6 Guides authored
Cal Poly, Team 21-24, Maness Winter 2015 Member of Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Members
8 Guides authored
1 Guide Comment
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 12
All Time: 4,115
