Asus X202E-UH31T Ethernet Port Replacement
  1. Asus X202E-UH31T Ethernet Port  Replacement, Ethernet Port: step 1, image 1 of 1
    • Remove the 9 1.2mm phillips head screws on the bottom of the computer using a small Phillips head screw driver.
  2. Asus X202E-UH31T Ethernet Port  Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open with your fingers
  3. Asus X202E-UH31T Ethernet Port  Replacement: step 3, image 1 of 2 Asus X202E-UH31T Ethernet Port  Replacement: step 3, image 2 of 2
    • Remove the 4 1.2mm phillips head screws with a small phillips head screw driver that held the Ethernet port in place.
    • Lift and remove the Ethernet port
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 313
