Asus X501A-RH31 Keyboard Replacement
  1. Asus X501A-RH31 Keyboard  Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Keyboard  Replacement: step 2, image 1 of 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Keyboard  Replacement: step 3, image 1 of 2 Asus X501A-RH31 Keyboard  Replacement: step 3, image 2 of 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Keyboard  Replacement, Keyboard: step 4, image 1 of 2 Asus X501A-RH31 Keyboard  Replacement, Keyboard: step 4, image 2 of 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Keyboard  Replacement: step 5, image 1 of 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Keyboard  Replacement: step 6, image 1 of 2 Asus X501A-RH31 Keyboard  Replacement: step 6, image 2 of 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Keyboard  Replacement: step 7, image 1 of 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Keyboard  Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
Romana Hruby
596 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 23
All Time: 1,350
