Asus X501A-RH31 LCD Replacement
  1. Asus X501A-RH31 LCD Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 LCD Replacement: step 2, image 1 of 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 LCD Replacement: step 3, image 1 of 2 Asus X501A-RH31 LCD Replacement: step 3, image 2 of 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 LCD Replacement, Keyboard: step 4, image 1 of 2 Asus X501A-RH31 LCD Replacement, Keyboard: step 4, image 2 of 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 LCD Replacement: step 5, image 1 of 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 LCD Replacement: step 6, image 1 of 2 Asus X501A-RH31 LCD Replacement: step 6, image 2 of 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 LCD Replacement: step 7, image 1 of 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 LCD Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 LCD Replacement, Fan: step 9, image 1 of 1
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
  10. Asus X501A-RH31 LCD Replacement: step 10, image 1 of 1
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
  11. Asus X501A-RH31 LCD Replacement: step 11, image 1 of 3 Asus X501A-RH31 LCD Replacement: step 11, image 2 of 3 Asus X501A-RH31 LCD Replacement: step 11, image 3 of 3
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
  12. Asus X501A-RH31 LCD Replacement, Motherboard: step 12, image 1 of 2 Asus X501A-RH31 LCD Replacement, Motherboard: step 12, image 2 of 2
    • Unscrew the six screws that hold the motherboard to the bottom of the laptop using a Phillips #00 screwdriver.
    • The six screws are 4.2 mm long, 5 mm in diameter.
  13. Asus X501A-RH31 LCD Replacement: step 13, image 1 of 2 Asus X501A-RH31 LCD Replacement: step 13, image 2 of 2
    Buy
    • Unlatch the data cable by using tweezers to lift the white tab and release the cable.
  14. Asus X501A-RH31 LCD Replacement: step 14, image 1 of 2 Asus X501A-RH31 LCD Replacement: step 14, image 2 of 2
    • Remove the cable on the left side of the motherboard.
    • Use tweezers to pull the white tab up in order to release this cable.
  15. Asus X501A-RH31 LCD Replacement: step 15, image 1 of 1
    • On the left side is a small piece of the motherboard. Unscrew the two screws holding this piece down with the Phillips #00 screwdriver.
    • The two screws are 6 mm long, 4.2 mm in diameter.
  16. Asus X501A-RH31 LCD Replacement: step 16, image 1 of 3 Asus X501A-RH31 LCD Replacement: step 16, image 2 of 3 Asus X501A-RH31 LCD Replacement: step 16, image 3 of 3
    • Release the connector cable on the back right side of the motherboard.
    • Peel off the tape with tweezers so that the cable can be released.
    • Using the black plastic spudger, push the back half of the cable towards the screen.
  17. Asus X501A-RH31 LCD Replacement: step 17, image 1 of 2 Asus X501A-RH31 LCD Replacement: step 17, image 2 of 2
    • Grip the motherboard firmly and pull the board leftward and upwards so that the ports on the right side escape their frames.
  18. Asus X501A-RH31 LCD Replacement: step 18, image 1 of 2 Asus X501A-RH31 LCD Replacement: step 18, image 2 of 2
    • On the back of the motherboard there are two screws that attach the LCD connector to the motherboard.
    • Unscrew the two screws using the Phillips #00 screwdriver.
    • These screws are 3 mm in length, 3.5 mm in diameter.
    • Pull the connector downwards and out.
  19. Asus X501A-RH31 LCD Replacement, Hinges: step 19, image 1 of 1
    • To detach the hinges, use the Phillips #00 screwdriver to unscrew the two top screws on both the left and right hinges.
    • The four screws are all the same. They are 6.2 mm in length, 4 mm in diameter.
  20. Asus X501A-RH31 LCD Replacement: step 20, image 1 of 1
    • Once both sides of the laptop are unscrewed, gently pull the upper half of the laptop off of the bottom half.
  21. Asus X501A-RH31 LCD Replacement: step 21, image 1 of 2 Asus X501A-RH31 LCD Replacement: step 21, image 2 of 2
    • Use the black plastic spudger to pry off the black squares on the bottom of the laptop screen, this reveals two screws.
    • Take caution when removing these squares as they will bend and crease.
  22. Asus X501A-RH31 LCD Replacement: step 22, image 1 of 1
    • Use the Phillips #00 screwdriver to unscrew the two screws at the bottom of the laptop screen.
    • The two screws are 6 mm long, 4mm in diameter.
  23. Asus X501A-RH31 LCD Replacement: step 23, image 1 of 1
    • Place the black plastic spudger between the top cover of the screen and the bottom of the laptop frame that rests on the table.
    • Push down on the black plastic spudger to pry the top cover off the screen of the laptop.
    • The screen is fragile and too much pressure applied will damage the screen.
  24. Asus X501A-RH31 LCD Replacement: step 24, image 1 of 1
    • At the bottom of the screen there are two screws on each hinge.
    • Unscrew the four screws using the Phillips #00 screwdriver.
    • The four screws are 3.5 mm long, 4.5 mm in diameter.
  25. Asus X501A-RH31 LCD Replacement: step 25, image 1 of 2 Asus X501A-RH31 LCD Replacement: step 25, image 2 of 2
    • At the top of the screen there are two screws on the left side and two screws on the right side of the laptop.
    • Using the Phillips head #00 screwdriver, unscrew the inside screw and then the outside screw.
    • All four screws are the same size. They are 4 mm in length, 4.2 mm in diameter.
  26. Asus X501A-RH31 LCD Replacement, LCD: step 26, image 1 of 1
    • Lift the screen up off the back panel enough to have access to the LCD cable connector, but not all the way.
    • Pull the cable gently down and out of the connector to disconnect it.
Romana Hruby
587 Reputation
5 Guides authored
One Comment
Awesome write up. Thanks a bunch!
Couple amendments based off of my experience:
Step 12: There may be more screws on the far right side of the motherboard
Step 23: You have to split the plastic hinge protrusions to get the bezel off
Marius Lukosevicius - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 748
