Asus X501A-RH31 Motherboard Replacement
  1. Asus X501A-RH31 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Motherboard Replacement: step 2, image 1 of 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Motherboard Replacement: step 3, image 1 of 2 Asus X501A-RH31 Motherboard Replacement: step 3, image 2 of 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Motherboard Replacement, Keyboard: step 4, image 1 of 2 Asus X501A-RH31 Motherboard Replacement, Keyboard: step 4, image 2 of 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Motherboard Replacement: step 5, image 1 of 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Motherboard Replacement: step 6, image 1 of 2 Asus X501A-RH31 Motherboard Replacement: step 6, image 2 of 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Motherboard Replacement: step 7, image 1 of 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Motherboard Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 Motherboard Replacement, Fan: step 9, image 1 of 1
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
  10. Asus X501A-RH31 Motherboard Replacement: step 10, image 1 of 1
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
  11. Asus X501A-RH31 Motherboard Replacement: step 11, image 1 of 3 Asus X501A-RH31 Motherboard Replacement: step 11, image 2 of 3 Asus X501A-RH31 Motherboard Replacement: step 11, image 3 of 3
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
  12. Asus X501A-RH31 Motherboard Replacement, Motherboard: step 12, image 1 of 2 Asus X501A-RH31 Motherboard Replacement, Motherboard: step 12, image 2 of 2
    • Unscrew the six screws that hold the motherboard to the bottom of the laptop using a Phillips #00 screwdriver.
    • The six screws are 4.2 mm long, 5 mm in diameter.
  13. Asus X501A-RH31 Motherboard Replacement: step 13, image 1 of 2 Asus X501A-RH31 Motherboard Replacement: step 13, image 2 of 2
    Buy
    • Unlatch the data cable by using tweezers to lift the white tab and release the cable.
  14. Asus X501A-RH31 Motherboard Replacement: step 14, image 1 of 2 Asus X501A-RH31 Motherboard Replacement: step 14, image 2 of 2
    • Remove the cable on the left side of the motherboard.
    • Use tweezers to pull the white tab up in order to release this cable.
  15. Asus X501A-RH31 Motherboard Replacement: step 15, image 1 of 1
    • On the left side is a small piece of the motherboard. Unscrew the two screws holding this piece down with the Phillips #00 screwdriver.
    • The two screws are 6 mm long, 4.2 mm in diameter.
  16. Asus X501A-RH31 Motherboard Replacement: step 16, image 1 of 3 Asus X501A-RH31 Motherboard Replacement: step 16, image 2 of 3 Asus X501A-RH31 Motherboard Replacement: step 16, image 3 of 3
    • Release the connector cable on the back right side of the motherboard.
    • Peel off the tape with tweezers so that the cable can be released.
    • Using the black plastic spudger, push the back half of the cable towards the screen.
  17. Asus X501A-RH31 Motherboard Replacement: step 17, image 1 of 2 Asus X501A-RH31 Motherboard Replacement: step 17, image 2 of 2
    • Grip the motherboard firmly and pull the board leftward and upwards so that the ports on the right side escape their frames.
  18. Asus X501A-RH31 Motherboard Replacement: step 18, image 1 of 2 Asus X501A-RH31 Motherboard Replacement: step 18, image 2 of 2
    • On the back of the motherboard there are two screws that attach the LCD connector to the motherboard.
    • Unscrew the two screws using the Phillips #00 screwdriver.
    • These screws are 3 mm in length, 3.5 mm in diameter.
    • Pull the connector downwards and out.
Romana Hruby
587 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 1,196
