Asus X502CA-BCL0901D Screen Frame Replacement
  1. Asus X502CA-BCL0901D Screen Frame Replacement, Screen Frame: step 1, image 1 of 2 Asus X502CA-BCL0901D Screen Frame Replacement, Screen Frame: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame.
  2. Asus X502CA-BCL0901D Screen Frame Replacement: step 2, image 1 of 1
    • Use the Philips #00 screwdriver to remove the 2 screws that were revealed in the previous step.
    • The screws are 20 mm in diameter and 50 mm long.
  3. Asus X502CA-BCL0901D Screen Frame Replacement: step 3, image 1 of 1
    • Using the plastic opening tool, pry the screen frame away from the screen.
  4. Asus X502CA-BCL0901D Screen Frame Replacement: step 4, image 1 of 1
    • Using your hands, grasp the screen frame at it's base near the laptop hinge.
    • While pulling the base of the screen frame away from the hinge horizontally, also lift up on the screen frame to disconnect it from the laptop hinge.
    • The space between the screen frame and laptop hinge is very small and the plastic for both parts is weak. However, a fair amount of force is required to disconnect the screen frame from the laptop hinge. Be careful during this step, or either of these plastic pieces may break.
Gregory Browne
501 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 23
All Time: 682
