Asus X54C HDD, RAM Memory Replacement
Video Overview
  1. Asus X54C HDD, RAM Memory Replacement, Battery: step 1, image 1 of 2 Asus X54C HDD, RAM Memory Replacement, Battery: step 1, image 2 of 2
    • Disconnect the charger and switch off the laptop.
    • Two keys keep locked battery.
  2. Asus X54C HDD, RAM Memory Replacement, HDD COVER: step 2, image 1 of 2 Asus X54C HDD, RAM Memory Replacement, HDD COVER: step 2, image 2 of 2
    • Remove the two Phillips screws.
    • Remove the HDD cover.
  3. Asus X54C HDD, RAM Memory Replacement: step 3, image 1 of 3 Asus X54C HDD, RAM Memory Replacement: step 3, image 2 of 3 Asus X54C HDD, RAM Memory Replacement: step 3, image 3 of 3
    • The HDD caddy iz secured by three Phillips screws. Remove them.
    • Use the black tape near to the SATA connector to slide and remove the HDD.
    • To remove the hard disk from the HDD caddy, unscrew the 2x Phillips screw.
  4. Asus X54C HDD, RAM Memory Replacement: step 4, image 1 of 3 Asus X54C HDD, RAM Memory Replacement: step 4, image 2 of 3 Asus X54C HDD, RAM Memory Replacement: step 4, image 3 of 3
    • There is one expansion slot for a memory module:
    • SO DIMM 204-pin, DDR3 SDRAM, 1333 MHz
    • Under the HDD cover is also the Wi-Fi card.
6 other people completed this guide.
ZFix
195,994 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
329 Members
1,452 Guides authored
4 Guide Comments
Bonjour,
Le Portable ASSUS X54C peut-il supporter 8Go de RAM alors qu’au départ, il en a 4 Go ?
merci pour le tuto.
CR (rousselclaude0995@orange.fr)
claude ROUSSEL - Reply
Bonjour, oui il peut aller jusqu'à 8Go maximum.
Brendan -
bonjour, un asus x54h peut il supporter 8go de ram ?
merci
mysoundsyourears - Reply
Bonjour,
Oui il peut supporter 8 Go de RAM maximum.
Brendan -
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 47
All Time: 12,441
