Asus X54C Keyboard Replacement
Video Overview
  1. Asus X54C Keyboard Replacement, Battery: step 1, image 1 of 2 Asus X54C Keyboard Replacement, Battery: step 1, image 2 of 2
    • Disconnect the charger and switch off the laptop.
    • Two keys keep locked battery.
  2. Asus X54C Keyboard Replacement, Keyboard: step 2, image 1 of 3 Asus X54C Keyboard Replacement, Keyboard: step 2, image 2 of 3 Asus X54C Keyboard Replacement, Keyboard: step 2, image 3 of 3
    • The Keyboard is held by 5x locking clips.
    • Use a tool with with a thin tip and lift slightly the KB from the left side.
    • Unlock clips one by one.
    • Disconnect the KB ribbon cable.
9 other people completed this guide.
ZFix
195,994 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
329 Members
1,452 Guides authored
2 Guide Comments
Thanks for the detailed vid! What are the materials used at 07:00-08:00 to clean and replace the paste? Specifically what's in the spray bottle and the syringe
Buster Cluster - Reply
Hello,
To clean the thermal paste, the author used a soft toothbrush (probably with isopropyllic alcohol).
The syringe contains a non-conductive thermal paste.
You can replace the toothbrush by cell polyurethane foam swabs and isopropilic alcohol to remove the old thermal paste if you want.
This is a laptop with a CPU that doesn't heat too much, so you can replace the original thermal paste by any non conductive thermal paste made to be used in computers it will be fine.
Brendan -
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 7,015
