Asus X5511M-RCLN03 Optical Drive Replacement
  1. Asus X5511M-RCLN03 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Position the laptop with the back cover facing upward.
  2. Asus X5511M-RCLN03 Optical Drive Replacement: step 2, image 1 of 1
    • Remove all nine 4 mm screws from the back cover.
  3. Asus X5511M-RCLN03 Optical Drive Replacement: step 3, image 1 of 1
    • Open the laptop with the keyboard facing upward."
  4. Asus X5511M-RCLN03 Optical Drive Replacement: step 4, image 1 of 1
    • Pry up the keyboard using a plastic spudger.
  5. Asus X5511M-RCLN03 Optical Drive Replacement: step 5, image 1 of 1
    • Remove the four, 4 mm screws using a Phillips #00 screwdriver.
  6. Asus X5511M-RCLN03 Optical Drive Replacement: step 6, image 1 of 1
    • Slide out the CD-ROM.
Andrew Hemphill
179 Reputation
1 Guide authored
3 Comments
Peer Review:
Title: This should be changed, as this portion of the device is not a DVD player. It is a CD ROM drive.
Step 1: This step is unclear and seems unnecessary. It should be removed, or reworded to be more specific: "Position the laptop with the back cover facing upward."
-Step 2: This step should specify what screwdriver to use. Using markup in the image would also help the user with locating the screws.
Step 3: This step is also unclear and seems unnecessary. It should be removed, or reworded: "Re-position the laptop with the back cover facing downward."
Courtney Clark - Reply
-Step 4: This step is missing articles (i.e. pry up “the” keyboard using a spudger). Also, it should specific what spudger to use (plastic). The user should know not to use a metal spudger on their device.
Step 5: This step is missing an article (remove “the” screw).
Step 6: This step is unclear, and should refer to the “CD ROM drive”, not a DVD player. It should be reworded to be more clear. Example: “Slide out the CD ROM drive to remove it.”
Edit the title and link to the guide so that they say CD-ROM drive instead of DVD player.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 715
