Asus X555LA-SI305041 Battery Replacement
  1. Asus X555LA-SI305041 Battery Replacement, Keyboard Assembly: step 1, image 1 of 1
    • Remove the following Phillips #0 screws from the lower case:
    • Six 9 mm screws
    • Four 11 mm screws
  2. Asus X555LA-SI305041 Battery Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to separate the top cover from the laptop.
    • Start by prying on the front of the laptop.
    • Continue prying around the cover and end just under the screen to release the front cover.
    • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
  3. Asus X555LA-SI305041 Battery Replacement: step 3, image 1 of 1
    • To release the ZIF latch, flip up the small white tab.
    • The connector may have a white base with a small grey rotating latch.
    • Pull the white ribbon cable out of the socket to disconnect it.
    • Very little force should be required to pull out the cable.
  4. Asus X555LA-SI305041 Battery Replacement: step 4, image 1 of 1
    • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
    • Gently pull the black and blue ribbon cable out of its connector.
  5. Asus X555LA-SI305041 Battery Replacement: step 5, image 1 of 1
    • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
  6. Asus X555LA-SI305041 Battery Replacement, Battery: step 6, image 1 of 1
    • Remove the three 5mm Phillips #0 screws securing the battery.
  7. Asus X555LA-SI305041 Battery Replacement: step 7, image 1 of 1
    • Gently remove battery from casing. The battery should remove easily.
    • Replace with new battery.
37 other people completed this guide.
10 Comments
Great and easy explanation! THANK YOU!
susanbedd - Reply
If the Asus f555la battery is buying at Chennai,if any availability?? Response to ashokkumara24@gmail.com.
Tommy Kumar - Reply
Hmmm. A couple of the screw lengths look a bit suspect. At step 1, the six 90mm screws? That’s nearly four inches long!! And at step 6, three 50mm screws? I haven’t started this yet, but my guess is that the respective lengths should be 9mm and 5mm respectively. But apart from that, the article reads very well; just what I was looking for. Thanks!
Albert - Reply
how many hours will this battery last? I bought a new laptop Asus x455L and the fully charged battery only lasts 3 hours. I’ve already adjusted my screen brightness to 40% and turned off WIFI & Bluetooth
Shaley - Reply
MY PROBLEM ……THE BATTERY HAD GROWN….INFLATED ITSELF…AND IN SO DOING, ELEVATED THE KEYBOARD AT THE  LEFT HAND SIDE, AND PREVENTED THE LID/SCREEN FROM CLOSING EVENLY.THE  BATTERY ALTHOUGH BLOATED,WAS STILL OPERATING  OK & WAS NOT LEAKING…..                               James King - 23/02 2018
James King - Reply
Past 24 Hours: 1
Past 7 Days: 37
Past 30 Days: 153
All Time: 82,136
