Asus X555LA-SI305041 RAM Replacement
  1. Asus X555LA-SI305041 RAM Replacement, RAM: step 1, image 1 of 1
    • Flip your laptop upside down and set it on a solid surface.
    • The RAM is located under the square cover on the bottom of the laptop.
  2. Asus X555LA-SI305041 RAM Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to remove the screw cover.
    • Make sure to keep the screw cover in a safe place. It is very easy to misplace.
  3. Asus X555LA-SI305041 RAM Replacement: step 3, image 1 of 1
    • Using a #0 Phillips screwdriver, unscrew the single 2.5mm screw on the RAM cover.
  4. Asus X555LA-SI305041 RAM Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to open the RAM cover.
  5. Asus X555LA-SI305041 RAM Replacement: step 5, image 1 of 1
    • With your finger, push the two metal tabs (one on each side) outward until the RAM card pops up.
  6. Asus X555LA-SI305041 RAM Replacement: step 6, image 1 of 1
    • Gently remove the RAM card.
18 other people completed this guide.
6 Comments
Why does my cover not have a screw? Same laptop, ASUS X555LA.
Bob - Reply
Are you seeing just a plastic circle? That has to be pried off... the screw is underneath.
sakichri - Reply
Hi! The battery have not be removed before this?
Ariel Bova - Reply
Ariel, the battery should be removed but this creates very unnecessary strain and stress on you. This is just an expansion bay, the actual ram is soldered on the motherboard, not serviceable by the end-user. Again, this is an expansion bay so what that means is if no RAM is in the to begin with, the laptop will be fine because there is still RAM directly on the motherboard. This is just so the end-user can add more RAM if they so choose.
Ryan S. - Reply
What if it comes with 2GB RAM already in the bay? Is it okay to proceed as long as the PC is shutdown? Will I lose any information by removing the 2GB RAM stick? Thanks. (My X555LAB has 6GB RAM total but I wish to replace the 2GB with an 8GB, 12GB total, even though this PC has the i7 CPU which I heard can handle more than 12GB of RAM, something like 32GB but apparently this PC can handle only 12GB even though it has an i7 8th gen processor) Any advice?
Brandon - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 71
All Time: 20,853
