Asus X751L Battery Replacement
  1. Asus X751L Battery Replacement, Keyboard: step 1, image 1 of 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Battery Replacement: step 2, image 1 of 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Battery Replacement: step 3, image 1 of 3 Asus X751L Battery Replacement: step 3, image 2 of 3 Asus X751L Battery Replacement: step 3, image 3 of 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
  5. Asus X751L Battery Replacement: step 5, image 1 of 2 Asus X751L Battery Replacement: step 5, image 2 of 2
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
  6. Asus X751L Battery Replacement: step 6, image 1 of 3 Asus X751L Battery Replacement: step 6, image 2 of 3 Asus X751L Battery Replacement: step 6, image 3 of 3
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
5 other people completed this guide.
John Enderton
612 Reputation
2 Guides authored
USF Tampa, Team 17-2, Blackwell Spring 2017 Member of USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Members
5 Guides authored
6 Guide Comments
Very nice, thank you !
anh
barzamjavel - Reply Share
very nice, thank you !
Anh
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - Reply Share
Your instructions were easy to follow. Thank you!!!
theresa collet - Reply Share
very helpful
khan - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 102
All Time: 14,054
