Asus X751L DVD Drive Replacement
  1. Asus X751L DVD Drive Replacement, Keyboard: step 1, image 1 of 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L DVD Drive Replacement: step 2, image 1 of 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L DVD Drive Replacement: step 3, image 1 of 3 Asus X751L DVD Drive Replacement: step 3, image 2 of 3 Asus X751L DVD Drive Replacement: step 3, image 3 of 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L DVD Drive Replacement, DVD Drive: step 4, image 1 of 1
    • With the keyboard panel open, face the laptop with the internal components facing towards you.
    • Remove the single 4.6mm Phillips #00 screw.
  5. Asus X751L DVD Drive Replacement: step 5, image 1 of 1
    • Pull the optical drive out.
2 other people completed this guide.
Carl Ravina
125 Reputation
1 Guide authored
USF Tampa, Team 17-2, Blackwell Spring 2017 Member of USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Members
5 Guides authored
1 Guide Comment
Spot on, took away any worries…………
paul pepper - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 54
All Time: 2,624
