Asus X751L Keyboard Replacement
  1. Asus X751L Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Keyboard Replacement: step 2, image 1 of 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Keyboard Replacement: step 3, image 1 of 3 Asus X751L Keyboard Replacement: step 3, image 2 of 3 Asus X751L Keyboard Replacement: step 3, image 3 of 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
3 other people completed this guide.
John Enderton
612 Reputation
2 Guides authored
USF Tampa, Team 17-2, Blackwell Spring 2017 Member of USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Members
5 Guides authored
1 Guide Comment
Looks easy enough, I have a Polish version qwertz keyboard , a 752L model-17" anyone know a compatible UK qwerty keyboard as a replacement? - or or a k. board shared with another model that will fit ? Asus service centre are less than helpful .!
phil.kath4 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 3,462
