Asus X751MA-DH01TQ Web Cam Replacement
  1. Asus X751MA-DH01TQ  Web Cam Replacement, Web Cam: step 1, image 1 of 2 Asus X751MA-DH01TQ  Web Cam Replacement, Web Cam: step 1, image 2 of 2
    • Turn the laptop upside down and locate the ten screws that hold the plate cover.
    • Remove all ten screws using a 00 Phillips head screwdriver.
  2. Asus X751MA-DH01TQ  Web Cam Replacement: step 2, image 1 of 2 Asus X751MA-DH01TQ  Web Cam Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, pry the keyboard off of the base of the laptop.
    • Lift up and remove the keyboard.
  3. Asus X751MA-DH01TQ  Web Cam Replacement: step 3, image 1 of 3 Asus X751MA-DH01TQ  Web Cam Replacement: step 3, image 2 of 3 Asus X751MA-DH01TQ  Web Cam Replacement: step 3, image 3 of 3
    • Remove eight 4.4 Phillips #00 screws attached to the hinge.
    • Hold the screen so it wont fall over.
  4. Asus X751MA-DH01TQ  Web Cam Replacement: step 4, image 1 of 3 Asus X751MA-DH01TQ  Web Cam Replacement: step 4, image 2 of 3 Asus X751MA-DH01TQ  Web Cam Replacement: step 4, image 3 of 3
    • Remove the stickers from the bottom left and right corners of the screen.
    • Use a 00 Phillips head screw driver to remove the four screws.
  5. Asus X751MA-DH01TQ  Web Cam Replacement: step 5, image 1 of 1
    • Use the plastic opening tool to take the screen apart.
  6. Asus X751MA-DH01TQ  Web Cam Replacement: step 6, image 1 of 2 Asus X751MA-DH01TQ  Web Cam Replacement: step 6, image 2 of 2
    • Remove the two 4mm Phillips #00 screws attached to the webcam.
  7. Asus X751MA-DH01TQ  Web Cam Replacement: step 7, image 1 of 3 Asus X751MA-DH01TQ  Web Cam Replacement: step 7, image 2 of 3 Asus X751MA-DH01TQ  Web Cam Replacement: step 7, image 3 of 3
    • Slowly pull up the webcam out of its slot, and begin to remove the wire.
  8. Asus X751MA-DH01TQ  Web Cam Replacement: step 8, image 1 of 2 Asus X751MA-DH01TQ  Web Cam Replacement: step 8, image 2 of 2
    • Continue to unravel the wire and peel the webcam wire sticker off.
  9. Asus X751MA-DH01TQ  Web Cam Replacement: step 9, image 1 of 2 Asus X751MA-DH01TQ  Web Cam Replacement: step 9, image 2 of 2
    • Once the sticker is peeled off pull the plug holding the webcam into the circuit board and the webcam is now disconnected.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 165
