Asus X751MA-DH01TQ Battery Replacement
  1. Asus X751MA-DH01TQ Battery Replacement, Battery: step 1, image 1 of 2 Asus X751MA-DH01TQ Battery Replacement, Battery: step 1, image 2 of 2
    • Turn the laptop upside down and locate the ten screws holding in the plate cover.
    • Remove all ten screws using a small Phillips head screwdriver.
  2. Asus X751MA-DH01TQ Battery Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to pry open and separate the keyboard from the plate cover carefully.
    • The actual keyboard will detach not the back cover.
  3. Asus X751MA-DH01TQ Battery Replacement: step 3, image 1 of 2 Asus X751MA-DH01TQ Battery Replacement: step 3, image 2 of 2
    • The battery contains wires connecting it to a circuit board. Slowly pull up and disconnect the wires from the board by pulling on the white tab.
  4. Asus X751MA-DH01TQ Battery Replacement: step 4, image 1 of 2 Asus X751MA-DH01TQ Battery Replacement: step 4, image 2 of 2
    • Remove the two 7mm screws holding the battery in place using a Phillips #00 screwdriver.
  5. Asus X751MA-DH01TQ Battery Replacement: step 5, image 1 of 1
    • Carefully lift the battery up out of place.
Lindsey Romero
174 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 36
All Time: 1,168
