Asus X751MA-DH01TQ Screen Replacement
  1. Asus X751MA-DH01TQ Screen Replacement, Screen: step 1, image 1 of 2 Asus X751MA-DH01TQ Screen Replacement, Screen: step 1, image 2 of 2
    • Turn the laptop upside down.
    • Unscrew the 10 screws on the bottom of the laptop using a PH00 screwdriver bit.
  2. Asus X751MA-DH01TQ Screen Replacement: step 2, image 1 of 3 Asus X751MA-DH01TQ Screen Replacement: step 2, image 2 of 3 Asus X751MA-DH01TQ Screen Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to detach and take off the keyboard.
  3. Asus X751MA-DH01TQ Screen Replacement: step 3, image 1 of 3 Asus X751MA-DH01TQ Screen Replacement: step 3, image 2 of 3 Asus X751MA-DH01TQ Screen Replacement: step 3, image 3 of 3
    • Remove the eight 5.5 Phillips #00 screws located at the top right and left hand side of panel.
    • There are four screws on each side.
  4. Asus X751MA-DH01TQ Screen Replacement: step 4, image 1 of 3 Asus X751MA-DH01TQ Screen Replacement: step 4, image 2 of 3 Asus X751MA-DH01TQ Screen Replacement: step 4, image 3 of 3
    • Remove the four 4mm Phillips #00 screws on the bottom left and right of the screen.
    • There are two screws on each side.
  5. Asus X751MA-DH01TQ Screen Replacement: step 5, image 1 of 1
    • Insert the plastic opening tool on the side of the screen and slide it all the way around to open the screen up.
  6. Asus X751MA-DH01TQ Screen Replacement: step 6, image 1 of 3 Asus X751MA-DH01TQ Screen Replacement: step 6, image 2 of 3 Asus X751MA-DH01TQ Screen Replacement: step 6, image 3 of 3
    • Remove the cords on the left and right side of the screen.
  7. Asus X751MA-DH01TQ Screen Replacement: step 7, image 1 of 3 Asus X751MA-DH01TQ Screen Replacement: step 7, image 2 of 3 Asus X751MA-DH01TQ Screen Replacement: step 7, image 3 of 3
    • Remove the eight total screws (4 on each side) that are on the side of the white part on the back of the screen.
  8. Asus X751MA-DH01TQ Screen Replacement: step 8, image 1 of 3 Asus X751MA-DH01TQ Screen Replacement: step 8, image 2 of 3 Asus X751MA-DH01TQ Screen Replacement: step 8, image 3 of 3
    • Remove the two 4mm Phillips #00 screws on the top corners of the back of the screen.
    • Remove the metal bars that you have just unscrewed.
  9. Asus X751MA-DH01TQ Screen Replacement: step 9, image 1 of 2 Asus X751MA-DH01TQ Screen Replacement: step 9, image 2 of 2
    • Peel back the bronze sticker that is connecting the white border piece to the outside edge of the screen.
  10. Asus X751MA-DH01TQ Screen Replacement: step 10, image 1 of 1
    • Use the plastic opening tool to pry open the white part away from the screen.
  11. Asus X751MA-DH01TQ Screen Replacement: step 11, image 1 of 2 Asus X751MA-DH01TQ Screen Replacement: step 11, image 2 of 2
    • Pull the white part out and pull out the rest of the screen.
Collen Bleigh
198 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 471
