Asus Z54C-JS31 Display Replacement
  1. Asus Z54C-JS31 Display Replacement, Battery: step 1, image 1 of 3 Asus Z54C-JS31 Display Replacement, Battery: step 1, image 2 of 3 Asus Z54C-JS31 Display Replacement, Battery: step 1, image 3 of 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Display Replacement, Display: step 2, image 1 of 3 Asus Z54C-JS31 Display Replacement, Display: step 2, image 2 of 3 Asus Z54C-JS31 Display Replacement, Display: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Open up the laptop and locate the two circular stickers at the bottom corners of the display.
    • Use a pair of tweezers to remove the two black stickers covering the screws.
    • Using a Philips #000 screwdriver, remove the two 9mm screws.
  3. Asus Z54C-JS31 Display Replacement: step 3, image 1 of 2 Asus Z54C-JS31 Display Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to pop off the plastic border around the display.
  4. Asus Z54C-JS31 Display Replacement: step 4, image 1 of 3 Asus Z54C-JS31 Display Replacement: step 4, image 2 of 3 Asus Z54C-JS31 Display Replacement: step 4, image 3 of 3
    • Remove the two 9mm screws from the top corners of the display with a Phillips #000 screwdriver.
    • Carefully lift the display out and place the screen face down on the keyboard.
  5. Asus Z54C-JS31 Display Replacement: step 5, image 1 of 1
    • Disconnect the display cable connector attached to the display.
Mark DeSimone
801 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 34
All Time: 289
