Asus Z54C-JS31 Hard Drive Replacement
  1. Asus Z54C-JS31 Hard Drive Replacement, Battery: step 1, image 1 of 3 Asus Z54C-JS31 Hard Drive Replacement, Battery: step 1, image 2 of 3 Asus Z54C-JS31 Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Hard Drive Replacement, HDD/RAM Cover Panel: step 2, image 1 of 2 Asus Z54C-JS31 Hard Drive Replacement, HDD/RAM Cover Panel: step 2, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 Hard Drive Replacement: step 3, image 1 of 2 Asus Z54C-JS31 Hard Drive Replacement: step 3, image 2 of 2
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Asus Z54C-JS31 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Remove the four 9mm screws holding the hard drive in place.
  5. Asus Z54C-JS31 Hard Drive Replacement: step 5, image 1 of 3 Asus Z54C-JS31 Hard Drive Replacement: step 5, image 2 of 3 Asus Z54C-JS31 Hard Drive Replacement: step 5, image 3 of 3
    • Slide the hard drive to the left to disconnect it.
    • Then pull on the black tab to lift the hard drive out of the laptop.
Mark DeSimone
801 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 129
