Asus Z54C-JS31 Keyboard Replacement
  1. Asus Z54C-JS31 Keyboard Replacement, Battery: step 1, image 1 of 3 Asus Z54C-JS31 Keyboard Replacement, Battery: step 1, image 2 of 3 Asus Z54C-JS31 Keyboard Replacement, Battery: step 1, image 3 of 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Keyboard Replacement, Keyboard: step 2, image 1 of 2 Asus Z54C-JS31 Keyboard Replacement, Keyboard: step 2, image 2 of 2
    • Turn the laptop to its normal position and open the display to show the keyboard.
    • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
  3. Asus Z54C-JS31 Keyboard Replacement: step 3, image 1 of 3 Asus Z54C-JS31 Keyboard Replacement: step 3, image 2 of 3 Asus Z54C-JS31 Keyboard Replacement: step 3, image 3 of 3
    • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
Mark DeSimone
801 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 279
