Asus Z54C-JS31 Optical Disc Drive Replacement
  1. Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: step 1, image 1 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: step 1, image 2 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: step 1, image 3 of 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Optical Disc Drive Replacement, Keyboard: step 2, image 1 of 2 Asus Z54C-JS31 Optical Disc Drive Replacement, Keyboard: step 2, image 2 of 2
    • Turn the laptop to its normal position and open the display to show the keyboard.
    • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
  3. Asus Z54C-JS31 Optical Disc Drive Replacement: step 3, image 1 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement: step 3, image 2 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement: step 3, image 3 of 3
    • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
  4. Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: step 4, image 1 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: step 4, image 2 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: step 4, image 3 of 3
    • Remove the 3mm screw with a Phillips #000 screwdriver.
    • Slide out the optical disc drive by pulling it away from the laptop.
Mark DeSimone
801 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 101
