Asus ZenBook Flip UX360C Screen Replacement
  1. Asus ZenBook Flip UX360C Screen Replacement, Screen: step 1, image 1 of 2 Asus ZenBook Flip UX360C Screen Replacement, Screen: step 1, image 2 of 2
    • Use a spudger to pry out the two rubber grommets from the front of the screen.
    • Remove the two 4mm Phillips Head #1 screws behind the grommets.
  2. Asus ZenBook Flip UX360C Screen Replacement: step 2, image 1 of 1
    • Use a large plastic opening tool to work around the outside of the screen and gently separate the two halves.
  3. Asus ZenBook Flip UX360C Screen Replacement: step 3, image 1 of 1
    • Remove the two 2 mm Phillips #00 camera screws.
    • Remove the 2 mm Phillips #0 upper circuit board screw.
    • Remove the 2 mm Phillips #0 lower circuit board screw.
  4. Asus ZenBook Flip UX360C Screen Replacement: step 4, image 1 of 2 Asus ZenBook Flip UX360C Screen Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to unplug the two ribbon cables from the top half of the screen.
    • Detach the upper circuit board cable using the same method.
  5. Asus ZenBook Flip UX360C Screen Replacement: step 5, image 1 of 3 Asus ZenBook Flip UX360C Screen Replacement: step 5, image 2 of 3 Asus ZenBook Flip UX360C Screen Replacement: step 5, image 3 of 3
    • On the bottom half of the screen remove the screen connection.
    • Disconnect the lower circuit board cable.
    • Separate the wiring from the casing, and remove the screen.
Kristopher Bright
397 Reputation
3 Guides authored
IUPUI, Team 1-4, Harley Spring 2022 Member of IUPUI, Team 1-4, Harley Spring 2022
IUPUI-HARLEY-S22S1G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 39
All Time: 1,894
