Asus ZenBook Flip UX360C Speaker Replacement
  1. Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: step 1, image 1 of 3 Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: step 1, image 2 of 3 Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: step 1, image 3 of 3
    • Turn laptop over.
    • Use the metal spudger to pry rubber feet off in the four corners of laptop.
  2. Asus ZenBook Flip UX360C Speaker Replacement, Speaker: step 2, image 1 of 1
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
  3. Asus ZenBook Flip UX360C Speaker Replacement: step 3, image 1 of 1
    • Remove all eleven 5 mm, Phillips #1 screws on the back cover.
  4. Asus ZenBook Flip UX360C Speaker Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to remove the keyboard panel.
  5. Asus ZenBook Flip UX360C Speaker Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
  6. Asus ZenBook Flip UX360C Speaker Replacement: step 6, image 1 of 3 Asus ZenBook Flip UX360C Speaker Replacement: step 6, image 2 of 3 Asus ZenBook Flip UX360C Speaker Replacement: step 6, image 3 of 3
    • Use nylon-tipped tweezeres to detach the battery connection.
  7. Asus ZenBook Flip UX360C Speaker Replacement: step 7, image 1 of 1
    • Remove all ten Phillips #1 battery retaining screws.
  8. Asus ZenBook Flip UX360C Speaker Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, carefully remove the connector connecting the speakers to the motherboard.
  9. Asus ZenBook Flip UX360C Speaker Replacement: step 9, image 1 of 3 Asus ZenBook Flip UX360C Speaker Replacement: step 9, image 2 of 3 Asus ZenBook Flip UX360C Speaker Replacement: step 9, image 3 of 3
    • Use your fingers or another object to slightly raise the bottom edge of the battery. The battery does not need to be fully removed to replace the speakers.
    • Use a nylon spudger or an opening tool to carefully pry the speaker from the chassis.
    • The speaker is held down with a mild adhesive. Work your way around the border to fully remove the speaker.
  10. Asus ZenBook Flip UX360C Speaker Replacement: step 10, image 1 of 2 Asus ZenBook Flip UX360C Speaker Replacement: step 10, image 2 of 2
    • Use tweezers to carefully unseat the cable connecting the left and right speakers.
  11. Asus ZenBook Flip UX360C Speaker Replacement: step 11, image 1 of 3 Asus ZenBook Flip UX360C Speaker Replacement: step 11, image 2 of 3 Asus ZenBook Flip UX360C Speaker Replacement: step 11, image 3 of 3
Kristopher Bright
397 Reputation
3 Guides authored
IUPUI, Team 1-4, Harley Spring 2022 Member of IUPUI, Team 1-4, Harley Spring 2022
IUPUI-HARLEY-S22S1G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 533
