Asus ZenFone 2 Laser Speaker Replacement
  1. Asus ZenFone 2 Laser Speaker Replacement, Speaker: step 1, image 1 of 3 Asus ZenFone 2 Laser Speaker Replacement, Speaker: step 1, image 2 of 3 Asus ZenFone 2 Laser Speaker Replacement, Speaker: step 1, image 3 of 3
    • Press and hold the power button until the menu appears with the option to power off.
    • If the power button is not working, proceed to step 2 and 3 to manually force shutdown the device.
  2. Asus ZenFone 2 Laser Speaker Replacement: step 2, image 1 of 3 Asus ZenFone 2 Laser Speaker Replacement: step 2, image 2 of 3 Asus ZenFone 2 Laser Speaker Replacement: step 2, image 3 of 3
    • On the lower right-hand side of the device, locate the notch and insert your finger nail to loosen the rear panel.
    • Continue to slide your finger around the seam to completely remove the rear cover.
  3. Asus ZenFone 2 Laser Speaker Replacement: step 3, image 1 of 3 Asus ZenFone 2 Laser Speaker Replacement: step 3, image 2 of 3 Asus ZenFone 2 Laser Speaker Replacement: step 3, image 3 of 3
    • Remove the sim card(s) and microSD card if installed.
    • Using your fingernail or spudger, remove the battery from the phone.
  4. Asus ZenFone 2 Laser Speaker Replacement: step 4, image 1 of 2 Asus ZenFone 2 Laser Speaker Replacement: step 4, image 2 of 2
    • Unscrew and remove the ten 2.5mm Phillips #00 screws.
    • Unscrew and remove the two 5.5mm Phillips #00 screws.
  5. Asus ZenFone 2 Laser Speaker Replacement: step 5, image 1 of 3 Asus ZenFone 2 Laser Speaker Replacement: step 5, image 2 of 3 Asus ZenFone 2 Laser Speaker Replacement: step 5, image 3 of 3
    • Grab the lower portion of the frame and lift up to remove it.
    • If the gasket around the camera lens falls out, simply put it back around the camera.
  6. Asus ZenFone 2 Laser Speaker Replacement: step 6, image 1 of 2 Asus ZenFone 2 Laser Speaker Replacement: step 6, image 2 of 2
    • Use a spudger or other tool to gently lift up one side of the speaker. Continue lifting until the speaker is detached from the phone.
    • Ensure correct alignment of the speaker contacts to the pin on the circuit board.
Ang Heng
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 389
