iFixit uses cookies to enhance site functionality, analyze traffic, and personalize ads. By using our site, you agree to our cookie use and Privacy Policy.
Asus ZenFone 5 lite Charging Port Replacement
Philipp Tolxdorf
Philipp Tolxdorf and 5 other contributors
Last updated on August 6, 2024
7 minutes
Easy
Incorrect Tools
Better Introduction
Tools
Show more…
  1. Asus ZenFone 5 lite Charging Port Replacement, Charging Port: step 1, image 1 of 2 Asus ZenFone 5 lite Charging Port Replacement, Charging Port: step 1, image 2 of 2
    • Use a thin plastic tool to peel the back cover of the phone off. Once the plastic tool has begun to pry the back off, slide the plastic tool around the edges of the phone to separate the adhesive holding the back on. Once all edges of the phone are disconnected, lift the back cover off.
    • Be careful to keep the cover and the rest of the phone close together so as not to break the connecting band between the touch sensor on the cover and the motherboard of the phone.
  2. Asus ZenFone 5 lite Charging Port Replacement: step 2, image 1 of 2 Asus ZenFone 5 lite Charging Port Replacement: step 2, image 2 of 2
    • Remove the seven Phillips #0 screws located on the bottom of the phone.
    • One of the seven screws is covered by a white sticker with the letters “CS” on it. This screw can be removed with the sticker still attached. Simply pierce through the sticker with the screwdriver and unscrew as normal.
  3. Asus ZenFone 5 lite Charging Port Replacement: step 3, image 1 of 2 Asus ZenFone 5 lite Charging Port Replacement: step 3, image 2 of 2
    • Use the nylon spudger to pry off the lower cover. Use the opening tool to help lift it off.
  4. Asus ZenFone 5 lite Charging Port Replacement: step 4, image 1 of 1
    • Use a prying tool to gently pry off the connection that was previously hidden by the black cover.
    • Use one finger to hold down the charging port circuit board while prying off the connection to ensure it does not break.
  5. Asus ZenFone 5 lite Charging Port Replacement: step 5, image 1 of 2 Asus ZenFone 5 lite Charging Port Replacement: step 5, image 2 of 2
    • Locate the gold-tipped black wire attached to the charging port circuit board.
    • Insert the plastic prying tool underneath the silver clasp and pry it off.
  6. Asus ZenFone 5 lite Charging Port Replacement: step 6, image 1 of 2 Asus ZenFone 5 lite Charging Port Replacement: step 6, image 2 of 2
    • Insert a plastic prying tool on the left side of the charging port. Gently lift up the charging port and then remove using your hand.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 364
