Asus Zenbook UM325U
  1. Asus Zenbook UM325U, Find all the screws and open the bottom: step 1, image 1 of 1
    • Be aware: 2 Torx are hidden under the back 2 feet of the laptop!
  2. Asus Zenbook UM325U, Pull the back with a spudger: step 2, image 1 of 2 Asus Zenbook UM325U, Pull the back with a spudger: step 2, image 2 of 2
    • This is the inside of the backplate: see all the small lips that attach to click the backplate to the chassis.
    • Use a spudger to open this up, starting from the front (the user-side) to the back (where the monitor attaches)
  3. Asus Zenbook UM325U, Replacing the SSD, Battery or go for further disassembly: step 3, image 1 of 3 Asus Zenbook UM325U, Replacing the SSD, Battery or go for further disassembly: step 3, image 2 of 3 Asus Zenbook UM325U, Replacing the SSD, Battery or go for further disassembly: step 3, image 3 of 3
    • Now that the chassis is opened, you can: 1) replace the ssd 2) replace the battery 3) continue onwards and dissasemble it further
    • Please do not forget to disconnect the battery cable when disassembling further!
hjheins
259 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 55
All Time: 1,622
