Asus Zenbook UX21e Battery Replacement
  1. Asus Zenbook UX21e Battery Replacement, Battery: step 1, image 1 of 3 Asus Zenbook UX21e Battery Replacement, Battery: step 1, image 2 of 3 Asus Zenbook UX21e Battery Replacement, Battery: step 1, image 3 of 3
    • Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
    • There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
  2. Asus Zenbook UX21e Battery Replacement: step 2, image 1 of 3 Asus Zenbook UX21e Battery Replacement: step 2, image 2 of 3 Asus Zenbook UX21e Battery Replacement: step 2, image 3 of 3
    • Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard.
  3. Asus Zenbook UX21e Battery Replacement: step 3, image 1 of 1
    • Remove the battery by unscrewing the five 3mm screws using a Phillips #1 screwdriver.
    • One at each corner and one in the center.
  4. Asus Zenbook UX21e Battery Replacement: step 4, image 1 of 2 Asus Zenbook UX21e Battery Replacement: step 4, image 2 of 2
    • Lift the battery directly up and remove it from the device.
4 other people completed this guide.
Zachary Eslick
756 Reputation
5 Guides authored
Cal Poly, Team S22-G1, Maness Spring 2018 Member of Cal Poly, Team S22-G1, Maness Spring 2018
CPSU-MANESS-S18S22G1
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 33
All Time: 4,105
