Asus Zenbook UX303L Cooling Fan Replacement
  1. Asus Zenbook UX303L Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 1
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Cooling Fan Replacement: step 2, image 1 of 3 Asus Zenbook UX303L Cooling Fan Replacement: step 2, image 2 of 3 Asus Zenbook UX303L Cooling Fan Replacement: step 2, image 3 of 3
    • Remove the rubber pads closer to the air vents and remove the two screws using a P0 screwdriver.
    • Remove all the nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Cooling Fan Replacement: step 3, image 1 of 2 Asus Zenbook UX303L Cooling Fan Replacement: step 3, image 2 of 2
    • Pull on the black flap to lift the LVDS cable next to the cooling fan.
  4. Asus Zenbook UX303L Cooling Fan Replacement: step 4, image 1 of 3 Asus Zenbook UX303L Cooling Fan Replacement: step 4, image 2 of 3 Asus Zenbook UX303L Cooling Fan Replacement: step 4, image 3 of 3
    • Remove the three screws from the hinges using a PH-1 screwdriver.
    • Open the device at a 90 degree angle to free the hinges.
  5. Asus Zenbook UX303L Cooling Fan Replacement: step 5, image 1 of 3 Asus Zenbook UX303L Cooling Fan Replacement: step 5, image 2 of 3 Asus Zenbook UX303L Cooling Fan Replacement: step 5, image 3 of 3
    • Remove the screws attached to the cooling fan with a PH-1 screwdriver.
    • Disconnect the wire attaching the cooling fan to the motherboard.
  6. Asus Zenbook UX303L Cooling Fan Replacement: step 6, image 1 of 2 Asus Zenbook UX303L Cooling Fan Replacement: step 6, image 2 of 2
    • Gently lift and slide the cooling fan out.
4 other people completed this guide.
Bianka Castaneda
469 Reputation
2 Guides authored
3 Comments
After the 6 step Would i then just remove the dust on the cooling fan and reassemble after that? or replace the fan as a whole
Sean Gerald Wong - Reply
I wish you guys had included the part number for the cooling fan.
mhyson - Reply
I think that it is important to recommend to remove the battery first, otherwise there is a risk of short...
Don't ask me how I know... :-(
Nmariotti - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 28
All Time: 6,159
