Asus Zenbook UX303L Keyboard Replacement
  1. Asus Zenbook UX303L Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Keyboard Replacement: step 2, image 1 of 3 Asus Zenbook UX303L Keyboard Replacement: step 2, image 2 of 3 Asus Zenbook UX303L Keyboard Replacement: step 2, image 3 of 3
    • Remove all the nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Keyboard Replacement: step 3, image 1 of 2 Asus Zenbook UX303L Keyboard Replacement: step 3, image 2 of 2
    • Remove the LVDS cable next to the cooling fan.
  4. Asus Zenbook UX303L Keyboard Replacement: step 4, image 1 of 3 Asus Zenbook UX303L Keyboard Replacement: step 4, image 2 of 3 Asus Zenbook UX303L Keyboard Replacement: step 4, image 3 of 3
    • Remove the three screws from the hinges using a PH-1 screwdriver.
    • Open the device at a 90 degree angle to free the hinges.
  5. Asus Zenbook UX303L Keyboard Replacement: step 5, image 1 of 3 Asus Zenbook UX303L Keyboard Replacement: step 5, image 2 of 3 Asus Zenbook UX303L Keyboard Replacement: step 5, image 3 of 3
    • Remove the screw attaching the cooling fan to the motherboard by using a PH-1 screwdriver.
    • Disconnect the wire attaching the cooling fan to the motherboard.
    • Gently lift and pull out the cooling fan.
  6. Asus Zenbook UX303L Keyboard Replacement: step 6, image 1 of 2 Asus Zenbook UX303L Keyboard Replacement: step 6, image 2 of 2
    • Remove the four screws attached to the black covered copper bar next to the cooling fan using a PH-1 screwdriver.
    • Gently lift and remove the copper bar.
  7. Asus Zenbook UX303L Keyboard Replacement: step 7, image 1 of 1
    • Remove the five screws from the battery pack using a PH-1 screwdriver.
  8. Asus Zenbook UX303L Keyboard Replacement: step 8, image 1 of 3 Asus Zenbook UX303L Keyboard Replacement: step 8, image 2 of 3 Asus Zenbook UX303L Keyboard Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Unhook the black, red, and white switch using the tweezers.
    • Detach the positive and negative red, white, yellow, and black switch.
    • Unhook the black and white coiled wire.
    • Lift and remove the battery pack.
  9. Asus Zenbook UX303L Keyboard Replacement: step 9, image 1 of 3 Asus Zenbook UX303L Keyboard Replacement: step 9, image 2 of 3 Asus Zenbook UX303L Keyboard Replacement: step 9, image 3 of 3
    • Remove the three screws attaching the drive to the motherboard using a PH-1 screwdriver.
    • Gently lift and pull out the drive.
  10. Asus Zenbook UX303L Keyboard Replacement: step 10, image 1 of 2 Asus Zenbook UX303L Keyboard Replacement: step 10, image 2 of 2
    • Remove the silver tape to free the fourth screw attaching the motherboard.
    • Remove the four screws attaching the motherboard using a PH-1 screwdriver.
  11. Asus Zenbook UX303L Keyboard Replacement: step 11, image 1 of 2 Asus Zenbook UX303L Keyboard Replacement: step 11, image 2 of 2
    • Detach the four wires connected to the motherboard using tweezers.
    • Gently lift up and pull out the motherboard.
  12. Asus Zenbook UX303L Keyboard Replacement: step 12, image 1 of 3 Asus Zenbook UX303L Keyboard Replacement: step 12, image 2 of 3 Asus Zenbook UX303L Keyboard Replacement: step 12, image 3 of 3
    • Remove the small piece of the motherboard on the lower left hand corner by removing the four screws using a PH-1 screwdriver.
    • Detach the black and red coiled wire from the motherboard using tweezers.
    • Gently lift and remove the small piece of the motherboard.
  13. Asus Zenbook UX303L Keyboard Replacement: step 13, image 1 of 2 Asus Zenbook UX303L Keyboard Replacement: step 13, image 2 of 2
    • Place the plastic opening tool under the corners of the keyboard and use it to detach the keyboard all around.
    • Gently lift and remove the keyboard from its place.
7 other people completed this guide.
Bianka Castaneda
469 Reputation
2 Guides authored
8 Comments
Please tell me where did you buy the keyboard replace, I am looking for it in order to do the replacement for an UX303L (with spanish or english layout with big enter key). Thanks.
Pm - Reply
Step 2: There are screws under the rubber pads (at least on the UX303L).
Peter Sutton - Reply
Step 9: Its removing the hard drive/SSD not RAM.
Step 13: Please show me how to remove the keyboard out. It will break some plastic to pull the keyboard out.
Thanks,
Quang
Quang Nguyen - Reply
Battery pack should be removed first (at least before step 3) in order to avoid possible power surge
Andrey Arkhipov - Reply
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 50
All Time: 21,216
