Asus Zenbook UX303L RAM Replacement
  1. Asus Zenbook UX303L RAM Replacement, RAM: step 1, image 1 of 1
    • Prior to installing RAM, it's good practice to ground yourself to avoid static discharge from damaging the internal components of the computer.
    • Avoid wearing static prone clothing or standing on carpet during the RAM replacement.
  2. Asus Zenbook UX303L RAM Replacement: step 2, image 1 of 2 Asus Zenbook UX303L RAM Replacement: step 2, image 2 of 2
    • Unscrew the eight 3 mm long screws on the bottom of the laptop along the parameter using a T5 Torx screwdriver.
    • Unscrew the one 8 mm long screw at the bottom of the laptop panel using a T5 Torx screwdriver.
    • Once all screws have been removed, carefully lift the bottom panel to reveal the RAM.
  3. Asus Zenbook UX303L RAM Replacement: step 3, image 1 of 3 Asus Zenbook UX303L RAM Replacement: step 3, image 2 of 3 Asus Zenbook UX303L RAM Replacement: step 3, image 3 of 3
    • Carefully pull apart the two clasps circled in red so that the RAM stick pops up.
    • Remove the stick of RAM from the SO-DIMM slot by gripping the edges of the RAM.
Evan Parker
136 Reputation
1 Guide authored
IUPUI, Team S1-G6, Harley Spring 2019 Member of IUPUI, Team S1-G6, Harley Spring 2019
IUPUI-HARLEY-S19S1G6
3 Members
7 Guides authored
1 Guide Comment
This is incomplete. There are two screws more hidden behind the rubber support points (on the hinges side) of the computer.
And you need some adhesive to fix this rubber squares in place after you fix the lid in place.
Ochirosi Paul - Reply
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 29
All Time: 4,211
