Asus Zenbook UX31A Fan Replacement
  1. Asus Zenbook UX31A Fan Replacement, Battery: step 1, image 1 of 2 Asus Zenbook UX31A Fan Replacement, Battery: step 1, image 2 of 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Fan Replacement: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Fan Replacement: step 3, image 1 of 1
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Fan Replacement: step 4, image 1 of 1
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Fan Replacement, Fan: step 5, image 1 of 2 Asus Zenbook UX31A Fan Replacement, Fan: step 5, image 2 of 2
    • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
    • Remove the bridge connector.
  6. Asus Zenbook UX31A Fan Replacement: step 6, image 1 of 3 Asus Zenbook UX31A Fan Replacement: step 6, image 2 of 3 Asus Zenbook UX31A Fan Replacement: step 6, image 3 of 3
    • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
  7. Asus Zenbook UX31A Fan Replacement: step 7, image 1 of 2 Asus Zenbook UX31A Fan Replacement: step 7, image 2 of 2
    • Disconnect the fan connector by pulling on it horizontally until it disconnects.
    • Remove the fan.
Brendan Walsh
227 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 593
