Asus Zenbook UX31A Wi-Fi Card Replacement
  1. Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 1 of 2 Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 2 of 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
  2. Asus Zenbook UX31A Wi-Fi Card Replacement: step 2, image 1 of 2 Asus Zenbook UX31A Wi-Fi Card Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
  3. Asus Zenbook UX31A Wi-Fi Card Replacement: step 3, image 1 of 1
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by gently pulling each one up.
    • They can be a little tricky to put back on so take your time and be gentle.
Sherwin
209 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 375
