Asus Zenbook UX31E Fan Replacement
  1. Asus Zenbook UX31E Fan Replacement, Back Cover: step 1, image 1 of 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Fan Replacement: step 2, image 1 of 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Fan Replacement, Fan: step 3, image 1 of 2 Asus Zenbook UX31E Fan Replacement, Fan: step 3, image 2 of 2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  4. Asus Zenbook UX31E Fan Replacement: step 4, image 1 of 1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  5. Asus Zenbook UX31E Fan Replacement: step 5, image 1 of 2 Asus Zenbook UX31E Fan Replacement: step 5, image 2 of 2
    • Unscrew the two screws that are across each other.
  6. Asus Zenbook UX31E Fan Replacement: step 6, image 1 of 2 Asus Zenbook UX31E Fan Replacement: step 6, image 2 of 2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
Sinh
101 Reputation
1 Guide authored
UW Tacoma, Team 1-2, Rose Winter 2017 Member of UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Members
9 Guides authored
One Comment
This guide does not explain how to replace the fan, but how to remove the fan.
How do you insert a new fan? (Specifically, how do you remove the fan from the component of which it is a part?)
Thank you in advance.
Albert - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,742
