Asus Zenbook UX31E Keyboard Replacement
  1. Asus Zenbook UX31E Keyboard Replacement, Back Cover: step 1, image 1 of 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Keyboard Replacement: step 2, image 1 of 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Keyboard Replacement, Battery: step 3, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement, Battery: step 3, image 2 of 2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  4. Asus Zenbook UX31E Keyboard Replacement: step 4, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 4, image 2 of 2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  5. Asus Zenbook UX31E Keyboard Replacement: step 5, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 5, image 2 of 2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
  6. Asus Zenbook UX31E Keyboard Replacement, Speaker: step 6, image 1 of 1
    • Use the plastic opening tool to pry open the back cover of the laptop.
    • Remove the bottom panel of the laptop.
  7. Asus Zenbook UX31E Keyboard Replacement: step 7, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 7, image 2 of 2
    • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
  8. Asus Zenbook UX31E Keyboard Replacement: step 8, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 8, image 2 of 2
    • Disconnect the sound cable from the motherboard.
  9. Asus Zenbook UX31E Keyboard Replacement: step 9, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 9, image 2 of 2
    • Using the plastic opening tool, pry open the speaker component from the computer.
  10. Asus Zenbook UX31E Keyboard Replacement, SSD: step 10, image 1 of 1
    • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
    • Peel back the warranty sticker to reveal the screw under it.
    • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
  11. Asus Zenbook UX31E Keyboard Replacement: step 11, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 11, image 2 of 2
    • Using your hand, pull the SSD out from its slot.
  12. Asus Zenbook UX31E Keyboard Replacement, Fan: step 12, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement, Fan: step 12, image 2 of 2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  13. Asus Zenbook UX31E Keyboard Replacement: step 13, image 1 of 1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  14. Asus Zenbook UX31E Keyboard Replacement: step 14, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 14, image 2 of 2
    • Unscrew the two screws that are across each other.
  15. Asus Zenbook UX31E Keyboard Replacement: step 15, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 15, image 2 of 2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
  16. Asus Zenbook UX31E Keyboard Replacement, Motherboard: step 16, image 1 of 3 Asus Zenbook UX31E Keyboard Replacement, Motherboard: step 16, image 2 of 3 Asus Zenbook UX31E Keyboard Replacement, Motherboard: step 16, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
    • Remove the press fit connector attaching the motherboard to the screen.
    • Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
  17. Asus Zenbook UX31E Keyboard Replacement: step 17, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 17, image 2 of 2
    • Lift gently and flip the motherboard over in the direction of the track pad.
    • Peel off the the yellow tape.
    • Detach the ZIF connector on the underside of the motherboard connecting it to the keyboard.
    • Remove the motherboard.
  18. Asus Zenbook UX31E Keyboard Replacement, Keyboard: step 18, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement, Keyboard: step 18, image 2 of 2
    • Remove the speaker assembly.
    • Lift gently to avoid damaging the speaker assembly.
  19. Asus Zenbook UX31E Keyboard Replacement: step 19, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 19, image 2 of 2
    • Gently peel back the yellow tape to reveal where the ribbon cable attaches to the track pad.
  20. Asus Zenbook UX31E Keyboard Replacement: step 20, image 1 of 1
    • Remove the 56 screws marked in red circles using a Phillips #000 screwdriver.
  21. Asus Zenbook UX31E Keyboard Replacement: step 21, image 1 of 1
    • Put your hand under the keyboard and gently push the keyboard up and away from the frame of the computer with your fingers.
    • Be very careful to not damage the keyboard itself when removing it.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 2,799
