Asus Zenbook UX32VD RAM Replacement
  1. Asus Zenbook UX32VD RAM Replacement, Bottom Panel: step 1, image 1 of 3 Asus Zenbook UX32VD RAM Replacement, Bottom Panel: step 1, image 2 of 3 Asus Zenbook UX32VD RAM Replacement, Bottom Panel: step 1, image 3 of 3
    Tool used on this step:
    T5 Torx Screwdriver
    $9.99
    Buy
  2. Asus Zenbook UX32VD RAM Replacement: step 2, image 1 of 3 Asus Zenbook UX32VD RAM Replacement: step 2, image 2 of 3 Asus Zenbook UX32VD RAM Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD RAM Replacement, RAM: step 3, image 1 of 3 Asus Zenbook UX32VD RAM Replacement, RAM: step 3, image 2 of 3 Asus Zenbook UX32VD RAM Replacement, RAM: step 3, image 3 of 3
    • Push away the RAM retaining arms from the RAM chip.
    • The RAM chip will spring up once the retaining arms are pushed away from the chip.
    • Remove the RAM chip completely.
5 other people completed this guide.
Paola
270 Reputation
1 Guide authored
CSU Fullerton, Team 2-2, Bruce Fall 2015 Member of CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Members
6 Guides authored
2 Guide Comments
Replaced the 4 GB RAM module in my UX32VD with an 8 GB Timetec Hynix IC DDR3 1600MHz PC3-12800 Non ECC Unbuffered 1.35V CL11 2Rx8 Dual Rank 204 Pin SODIMM Laptop Notebook Computer Memory Ram Module using this guide. It worked like a charm. Thank you for posting the guide!
Le Zap - Reply
Worked like a charm on a UX32VD. Installed a "Kingston SO-DDR3L-RAM ValueRAM 1600 MHz 1x 8 GB" in 3min
HUGE DIFFERENCE
Thank you very much!
PS. There was a foil wrapper around the old RAM that I removed and put around the new RAM. Heat dissipation I imagine
Valentin - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 4,940
