Asus Zenfone 3 Max Battery Replacement
  1. Asus Zenfone 3 Max Battery Replacement, Back cover: step 1, image 1 of 2 Asus Zenfone 3 Max Battery Replacement, Back cover: step 1, image 2 of 2
    • Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  2. Asus Zenfone 3 Max Battery Replacement: step 2, image 1 of 1
    • Once the original cover has been removed, apply the new cover to the back of the phone with careful pressure.
  3. Asus Zenfone 3 Max Battery Replacement, Battery: step 3, image 1 of 3 Asus Zenfone 3 Max Battery Replacement, Battery: step 3, image 2 of 3 Asus Zenfone 3 Max Battery Replacement, Battery: step 3, image 3 of 3
    • Gently disconnect the gold connection cable indicated by the red circle in the corresponding picture.
    • Pull back on the black adhesive tab that is adhered to the top of the battery. Tab removal is marked in the corresponding picture with a orange circle.
    • Once the gold connection cable and black adhesive tab are no longer connected to the battery, the battery can be removed.
  4. Asus Zenfone 3 Max Battery Replacement: step 4, image 1 of 3 Asus Zenfone 3 Max Battery Replacement: step 4, image 2 of 3 Asus Zenfone 3 Max Battery Replacement: step 4, image 3 of 3
    • Next, remove the battery by gently pulling on the blue removal tab located at the bottom of the device battery.
    • Completely remove existing device battery.
3 Comments
I need to replace asus zenfone 3 max whole body lcd & what ever the requirements i want to know that it can be replaced or it is dead
Hassan Shahzad - Reply
Part not available on amazon & please bring your store to India, as the market is flooded with a ton of counterfeited products.
Deepank Malhotra - Reply
Asus Zenfone max 3, 5.5 এর ব্র্যাক সেল ও চার্জিং লজিক পাওয়া যাবে কি, জানাবেন প্লিজ
mafijur1122 - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 43
All Time: 3,241
