Atari 5200 Controller Side Buttons Replacement
  1. Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: step 1, image 1 of 3 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: step 1, image 2 of 3 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: step 1, image 3 of 3
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
  2. Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: step 2, image 1 of 2 Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: step 2, image 2 of 2
    • Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
    • Realign the buttons over the sensors/clean the sensor contacts.
    • Be careful when reassembling your buttons. Make sure the black buttons are aligned properly over the silver sensors on the flex board
    • Also, be careful to properly align the bottom of the joystick with the pots (white levers)
  3. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: step 3, image 1 of 2 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: step 3, image 2 of 2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: step 4, image 1 of 2 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: step 4, image 2 of 2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  5. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: step 5, image 1 of 3 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: step 5, image 2 of 3 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: step 5, image 3 of 3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
Alan Abelson
233 Reputation
5 Guides authored
USF Tampa, Team 13-1, Staggers Fall 2014 Member of USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,246
