Atari 5200 Game Cartridge Disassembly
  1. Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: step 1, image 1 of 3 Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: step 1, image 2 of 3 Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: step 1, image 3 of 3
    • Flip the cartridge over.
    • Unscrew the single screw on the back.
    • Carefully pry apart the casing. There are six (6) tabs that need to be released, three (3) each side. If you're not careful they will break. (experience has taught me)
    • Set aside any case parts after dissassembly.
  2. Atari 5200 Game Cartridge Disassembly, Cleaning the Parts: step 2, image 1 of 1
    • Unscrew the board casing, and remove it.
    • Use a compressed air can to blow off any excess dust off the board.
    • Use an alcohol-dabbed cloth to wipe down the gold-plated contacts of the board.
  3. Atari 5200 Game Cartridge Disassembly, Reassembly: step 3, image 1 of 3 Atari 5200 Game Cartridge Disassembly, Reassembly: step 3, image 2 of 3 Atari 5200 Game Cartridge Disassembly, Reassembly: step 3, image 3 of 3
    • Place the two contact protectors together.
    • Place the spring on the knob in the cartridge.
  4. Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: step 4, image 1 of 3 Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: step 4, image 2 of 3 Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: step 4, image 3 of 3
    • Thread the spring into the connected plates.
    • Push the plates into the cartridge against the pressure of the spring.
  5. Atari 5200 Game Cartridge Disassembly, Finishing up: step 5, image 1 of 3 Atari 5200 Game Cartridge Disassembly, Finishing up: step 5, image 2 of 3 Atari 5200 Game Cartridge Disassembly, Finishing up: step 5, image 3 of 3
    • Place the chip in the case.
    • It should "pop" into place.
    • Screw the other side of the case on.
Be sure to test the game, and if freezing still occurs, check the contacts once again.
3 other people completed this guide.
Zach Petryszyn
21 Reputation
3 Guides authored
USF Tampa, Team 13-1, Staggers Fall 2014 Member of USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Members
17 Guides authored
2 Comments
I’m curious to see the Atari 2600 cartridge inside but I can’t get my hands on one.
The official meme centre. - Reply
it's not a 2600 cart. the systems have similarities, but they are not pin compatible, nor are they software compatible. the 5200 is its own thing.
Gorilla Sapiens - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 42
All Time: 2,984
