Atari 5200 Motherboard Cleaning
  1. Atari 5200 Motherboard Cleaning, Atari 5200 Motherboard Cleaning: step 1, image 1 of 1
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
  2. Atari 5200 Motherboard Cleaning: step 2, image 1 of 1
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
  3. Atari 5200 Motherboard Cleaning, Access: Granted: step 3, image 1 of 1
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
Zach Petryszyn
21 Reputation
3 Guides authored
USF Tampa, Team 13-1, Staggers Fall 2014 Member of USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Members
17 Guides authored
One Comment
This "tutorial" does not even cover gaining access to the motherboard.
Dannot - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 2,799
