Atari 5200 Motherboard Cleaning
Zach Petryszyn
Zach Petryszyn and 12 other contributors
Last updated on December 21, 2021
15 - 30 minutes
Easy
Introduction
Go to step 1
This guide will explain how to disassemble your Atari system in order to clean the dust from the motherboard. Dust build up can cause electrical problems for your Atari system, possibly causing it run very slow or not turn on. [WARNING: follow instructions as carefully as possible as failure to do so can damage your system.]
iFixit earns commission when you buy through these links.
  1. Atari 5200 Motherboard Cleaning, Atari 5200 Motherboard Cleaning: step 1, image 1 of 1
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
  2. Atari 5200 Motherboard Cleaning: step 2, image 1 of 1
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
  3. Atari 5200 Motherboard Cleaning, Access: Granted: step 3, image 1 of 1
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
Zach Petryszyn
21 Reputation
3 Guides authored
USF Tampa, Team 13-1, Staggers Fall 2014 Member of USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Members
17 Guides authored
1 Guide Comment
This "tutorial" does not even cover gaining access to the motherboard.
Dannot - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 2,804
