Atari Flashback 2 Console Power Button Replacement
  1. Atari Flashback 2 Console Power Button Replacement, Console Power Button: step 1, image 1 of 3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: step 1, image 2 of 3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: step 1, image 3 of 3
    • Using the screwdriver and PH1 bit, unscrew the five 10.0 mm screws.
    • One is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Console Power Button Replacement: step 2, image 1 of 3 Atari Flashback 2 Console Power Button Replacement: step 2, image 2 of 3 Atari Flashback 2 Console Power Button Replacement: step 2, image 3 of 3
    • Use a PH1 screwdriver to unscrew the two 9.0 mm screws on the circuit board that corresponds to the red power button.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    • A spring may pop out.
Faith Julian
205 Reputation
2 Guides authored
1 Guide Comment
Hello. I just bought a used atari flashback 2 and when I turn it on it seems that the power button is a little tricky. I wiggle the button in and out and half way etc. then sometimes I can get it to turn on. Once on, the video 'pulses' on and off and a pulsing sound is noticeable. Is it just a faulty power button or is it something worse like a power regulator. I've taken it apart and all seems to be ok looking ie. no burnt fuses etc.  Can you help?  ~Brad Beachin~
bradbeachin - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 17
All Time: 1,087
