Atari Flashback 2 Difficulty Button Replacement
  1. Atari Flashback 2 Difficulty Button Replacement, Difficulty Button: step 1, image 1 of 3 Atari Flashback 2 Difficulty Button Replacement, Difficulty Button: step 1, image 2 of 3 Atari Flashback 2 Difficulty Button Replacement, Difficulty Button: step 1, image 3 of 3
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Difficulty Button Replacement: step 2, image 1 of 2 Atari Flashback 2 Difficulty Button Replacement: step 2, image 2 of 2
    • Unscrew the two 10.0 mm Phillips #1 screws, and gently pull back the green circuit board.
    • Remove gently. The circuit board is connected by wire to the board. Removing the cable from the console case may allow more slack.
    • The button springs may be under compression.
Aaron Ramadan
135 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 507
