Atari Flashback 2 Joystick Button Replacement
  1. Atari Flashback 2 Joystick Button Replacement, Joystick Button: step 1, image 1 of 1
    • Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
    • Remove the bottom panel from the joystick.
  2. Atari Flashback 2 Joystick Button Replacement: step 2, image 1 of 1
    • Unscrew the single 8.0 mm Phillips#1 screw holding the circuit board in place.
    • Remove the circuit board from the joystick housing.
  3. Atari Flashback 2 Joystick Button Replacement: step 3, image 1 of 1
    • Inspect the circuit board for dirt, corrosion or damage. If necessary, clean the indicated contact using a cotton swab.
  4. Atari Flashback 2 Joystick Button Replacement: step 4, image 1 of 1
    • Remove the button from the joystick housing. Check for dirt or debris that may obstruct its movement. If the button is broken, replace it.
Daniel Hoffman
209 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 6
All Time: 596
