Atari Flashback 2 Joystick Replacement
  1. Atari Flashback 2 Joystick Replacement, Joystick: step 1, image 1 of 3 Atari Flashback 2 Joystick Replacement, Joystick: step 1, image 2 of 3 Atari Flashback 2 Joystick Replacement, Joystick: step 1, image 3 of 3
    • Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
    • Remove the bottom panel from the joystick.
  2. Atari Flashback 2 Joystick Replacement: step 2, image 1 of 2 Atari Flashback 2 Joystick Replacement: step 2, image 2 of 2
    • Use the screwdriver with the PH1 bit to remove the one 10.0 mm screw on the circuit board.
    • Remove the circuit board.
  3. Atari Flashback 2 Joystick Replacement: step 3, image 1 of 2 Atari Flashback 2 Joystick Replacement: step 3, image 2 of 2
    • Remove the rubber pad from the joystick.
  4. Atari Flashback 2 Joystick Replacement: step 4, image 1 of 2 Atari Flashback 2 Joystick Replacement: step 4, image 2 of 2
    • Using a plastic opening tool, poke into the six notches around the bottom of the joystick housing.
    • The joystick's rubber boot will come loose, but stay in place.
  5. Atari Flashback 2 Joystick Replacement: step 5, image 1 of 2 Atari Flashback 2 Joystick Replacement: step 5, image 2 of 2
    • The joystick will now unscrew (counter-clockwise) and you can disassemble the top of the controller into these four parts.
Faith Julian
205 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,521
