Atari Flashback 2 Reset and Select Button Replacement
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: step 1, image 1 of 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: step 1, image 2 of 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: step 1, image 3 of 3
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Reset and Select Button Replacement: step 2, image 1 of 3 Atari Flashback 2 Reset and Select Button Replacement: step 2, image 2 of 3 Atari Flashback 2 Reset and Select Button Replacement: step 2, image 3 of 3
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
Gabriel Robinson
85 Reputation
1 Guide authored
2 Comments
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Reply
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 805
