Atari Lynx Battery Wire Replacement
  1. Atari Lynx Battery Wire Replacement, Atari Lynx: step 1, image 1 of 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Atari Lynx Battery Wire Replacement: step 2, image 1 of 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Atari Lynx Battery Wire Replacement: step 3, image 1 of 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Atari Lynx Battery Wire Replacement: step 4, image 1 of 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Atari Lynx Battery Wire Replacement, Battery Wires: step 5, image 1 of 1
    • Desolder both the black and red wire as shown.
    • If you need help with basic desoldering, click here.
  6. Atari Lynx Battery Wire Replacement: step 6, image 1 of 1
    • Desolder the black wire as shown.
  7. Atari Lynx Battery Wire Replacement: step 7, image 1 of 2 Atari Lynx Battery Wire Replacement: step 7, image 2 of 2
    • Desolder the white wire and then the red wire as shown.
  8. Atari Lynx Battery Wire Replacement: step 8, image 1 of 1
    • Desolder the white wire as shown in order for the battery pack to be completely removed from the device.
John Lopez
446 Reputation
4 Guides authored
Cal Poly, Team 1-42, Maness Winter 2014 Member of Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 9
Past 30 Days: 22
All Time: 2,080
