Atmega328P Microcontroller Replacement for Arduino Board
  1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: step 1, image 1 of 1
    • Place the Arduino UNO R3 board on a flat clean surface.
  2. Atmega328P Microcontroller Replacement for Arduino Board: step 2, image 1 of 2 Atmega328P Microcontroller Replacement for Arduino Board: step 2, image 2 of 2
    • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
    • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
  3. Atmega328P Microcontroller Replacement for Arduino Board: step 3, image 1 of 2 Atmega328P Microcontroller Replacement for Arduino Board: step 3, image 2 of 2
    • Repeat the same process on the other side.
    • Lift both sides evenly to prevent any damage to the pins.
  4. Atmega328P Microcontroller Replacement for Arduino Board: step 4, image 1 of 3 Atmega328P Microcontroller Replacement for Arduino Board: step 4, image 2 of 3 Atmega328P Microcontroller Replacement for Arduino Board: step 4, image 3 of 3
    • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
  5. Atmega328P Microcontroller Replacement for Arduino Board: step 5, image 1 of 1
    • Remove replacement microcontroller out of packaging.
  6. Atmega328P Microcontroller Replacement for Arduino Board: step 6, image 1 of 1
    • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
    • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
  7. Atmega328P Microcontroller Replacement for Arduino Board: step 7, image 1 of 2 Atmega328P Microcontroller Replacement for Arduino Board: step 7, image 2 of 2
    • Gently press the microcontroller into the dip socket
2 other people completed this guide.
Youssef Qteshat
193 Reputation
1 Guide authored
UC Davis, Team 5-5, Morris Winter 2023 Member of UC Davis, Team 5-5, Morris Winter 2023
UCD-MORRIS-W23S5G5
2 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 50
All Time: 984
