Audio Technica ATH-AD500 Right Headphone Cable Replacement
  1. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Speaker Assembly: step 1, image 1 of 1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Right Headphone Cable Replacement: step 2, image 1 of 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Right Headphone Cable Replacement: step 3, image 1 of 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: step 4, image 1 of 2 Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: step 4, image 2 of 2
    • Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you soldered will be hot so let the soldered joints cool for before handling again.
  5. Audio Technica ATH-AD500 Right Headphone Cable Replacement: step 5, image 1 of 2 Audio Technica ATH-AD500 Right Headphone Cable Replacement: step 5, image 2 of 2
    • Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference How To Solder and Desolder Connections.
3 other people completed this guide.
Melanie Reis
227 Reputation
5 Guides authored
Cal Poly, Team 17-19, Forte Winter 2013 Member of Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Members
17 Guides authored
3 Comments
Where can i buy a replacement cable? Cant seem to find it anywhere.
Stefan Rasmussen - Reply
Way late, but I would second information about finding a replacement cable.
Mateo Gomez - Reply
Hey guys, if any of you managed to find the correct cable I would like to know :) I want to fix my A900Xs
Erez Dahan - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 4,594
