Audio-Technica AT-LP60BK-BT Belt Drive Replacement
  1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: step 1, image 1 of 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: step 1, image 2 of 2
    • Open the top plastic cover and remove the record and rubber mat.
  2. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 2, image 1 of 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 2, image 2 of 2
    • Find the belt underneath the platter by rotating the platter to the correct place.
    • Remove the belt from the motor pulley.
  3. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 3, image 1 of 1
    • Take the platter off by pulling it straight up.
  4. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 4, image 1 of 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 4, image 2 of 2
    • Remove the old belt.
  5. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 5, image 1 of 1
    • Turn platter upside down.
  6. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 6, image 1 of 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 6, image 2 of 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 6, image 3 of 3
    • Place the new belt around the inner lap on the upside-down platter.
    • Make sure the rubber band is flat on the platter, with no flipping.
  7. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 7, image 1 of 1
    • Turn the platter around.
    • Grab the belt around with a finger through one of the holes in the platter.
  8. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 8, image 1 of 1
    • Put the platter straight down.
  9. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 9, image 1 of 1
    • Put the belt around the motor pulley.
  10. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 10, image 1 of 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 10, image 2 of 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: step 10, image 3 of 3
    • Test the function by spinning the platter and put the rubber mat into place.
Zonghao Li
208 Reputation
1 Guide authored
One Comment
Thank you so much!
Joe - Reply
Past 24 Hours: 25
Past 7 Days: 197
Past 30 Days: 774
All Time: 9,562
